H9 Output Levels
Home › Forums › Products › Stompboxes › H9 Output Levels
    • #141205
        mcmullers wrote:
        1. What type of output does the H9 produce? Line Level or Instrument Level
        It will essentially give you much the same level out as you put in. Note that it does not enjoy a very hot line level.
        mcmullers wrote:
        2. Balanced or Unbalanced
        Unbalanced.
        mcmullers wrote:
        3.If I am connecting the 1/4 outputs to an audio interface to bring them to the daw, should I use balanced 1/4" to male XLR cables for best quality, my audio interface accepts both 1/4 and XLR.
        It really depends on the audio interface. Ideally try both and see what works.
      • #141208
        mcmullers
          Thank you
          Best forum I have ever used, consistent quick answers happy customers.
          Have a nice day
        • #112974
          mcmullers
            Hello, hope somebody can help me
            3.If I am connecting the 1/4 outputs to an audio interface to bring them to the daw, should I use balanced 1/4″ to male XLR cables for best quality, my audio interface accepts both 1/4 and XLR.
            Thank you in advance
            Adrián
