H9 – Pitch Factor – H910 – Way to split Pitch A and Pitch B to Left Right?
Home › Forums › Products › Stompboxes › H9 – Pitch Factor – H910 – Way to split Pitch A and Pitch B to Left Right?
    • #114742
      netgig
        I am trying to recreate the Classic Eddie Van Halen sound using the H9 – Pitch Factor – H910 setting using two amps and I want Pitch A to go to Amp A and Pitch B to go to Amp B. Is that possible?
      • #149258
          Further explanation and examples here:
          https://www.eventideaudio.com/comment/28731#comment-28731
          If you’re running mono before your H9 / PitchFactor, use Input 1.  Pitch A / Output 1 goes to Amp A.  Pitch B / Output 2 goes to Amp B.  Check to see that PITCH MIX is centered at A10+B10, for equal distribution.
        • #149264
          netgig
            Wow, yes that is exactly what I am looking for. I can’t wait to get home and try this! THANK YOU
