H9 Preset scrolling using Boss SY-300 as controller
Home Forums Products Stompboxes H9 Preset scrolling using Boss SY-300 as controller
    • #114433
      This is kind of a newer setup experiment for me, but when I try using a Boss SY-300 to scroll up and down through presets in two H9’s, the program numbers change just fine and the active lights stay on, but the audio disappears from both H9’s. The first H9 shows a signal input, but no output. Of course the second H9 shows no audio in or out. When I hit the active button for bypass, I get the bypass signal just fine, hit the active button again, the active light comes on, and back to silence. I have to power off the H9’s to get them working normally again. Both do the exact same thing.
      I have used a Tech 21 Midi Moose on the H9’s without any such issues, but I would like to shrink the footprint a bit. I am digging in the SY-300 to see what kind of signal it is sending that is causing the issue, but what is weird is I can’t find the parameter in the H9 that might be being messed with by the SY-300. Both H9 software is up to date. (One Max, one Core)
      Any ideas?
      Thx!
    • #147480
      gkellum
        I'd double check that you don't have the Input or Output Volume of the H9 mapped to a MIDI CC message. We had a problem in the past where MIDI bank change messages were being misrecognized as MIDI CCs and muting the H9.  In H9 Control you can check this by going to Pedal Settings in the bottom menubar, go to MIDI Settings, and go to Assign MIDI CC messages to pedal functions.
      • #147485
        Yay, lol, I set all the input and output volumes to MIDI CC 127 and it works.Thanks!!
        I didn’t really understand how the midi cc worked and I tried the No Mapping setting before with the input and output but that didn’t work.
        Thanks again!
