Had an H9 for about 5 years. Every once in a while it will just stop sending effects to the outs.
It not part of a pedalboard. It’s on a shelf. Nobody is stepping on bypass.
No its not in bypass.
I can turn up the gain until I hear digital noise but nothing.
Tried;
enabling/disabling bypass,
changing bypass mode,
changing kill dry,
power cycling the pedal,
reloading the preset,
enabling/disabling global mix.
Nothing works.
This happens a couple times a year and I never have found a solution. It will just start working again sometimes.
Now cannot use this to play out because I can’t trust it to be there.
And worse I have no SOP to recover from this effectless state.
