H9 to replace my Space and Timefactor
Home Forums Products Stompboxes H9 to replace my Space and Timefactor
    • #114976
      4_cuerdas
        I use a Space and a Timefactor they are connected together via MIDI (Timefactor is the master) and I use as well an aux switch and a expression pedal. The aux switch is a digitech fsx3 and it is connected to the Timefactor to the bank down, tap tempo and infinite loop parameters, the expression pedal is also connected to the Timefactor. My question is, would I be able to use the H9 in the exact same way as my two stomp boxes? The main reason I want to replace the two stomp boxes with an H9 is because real state of my pedalboard.
        Is there somebody in the eventide community that can help med with some advice?
        Thanks in advance.
        Cheers!
      • #150243
        bohan
          4_cuerdas wrote:
          Would I be able to use the H9 in the exact same way as my two stomp boxes?
          Digitech fsx3 can work the exactly same way for the H9. But you can only use one algorithm on the H9. It cannot run a TimeFactor and a PitchFactor algorithms simultaneously.
          • #150244
            4_cuerdas
              I see, that is not a problem, I think that to be limited is a good thing. But do you know if it is possible to switch presets up and down with a MIDI pedal?
              Cheers
            • #150249
              bohan
                4_cuerdas wrote:
                But do you know if it is possible to switch presets up and down with a MIDI pedal? Cheers
                Yes. You can easily assign functions of MIDI CC/PC messages in H9 Control (Pedal Settings -> MIDI Settings).
                If you haven't used it before, I recommend you check it out: https://www.eventideaudio.com/products/software/bluetooth/h9-control
              • #150250
                4_cuerdas
                  Thanks!. The H9 is on ITS way !, I believe it will be in my hands by Saturday !:-)
              • #150248
                Given To Fly
                  Yes
