H9 Update Messing Up Algorithm Sounds
Home › Forums › Products › Stompboxes › H9 Update Messing Up Algorithm Sounds
    • #147477
        If you have not already done so, try restoring the unit to "Restoring Factory Presets and System Settings" (see UM).
      • #114431
        I just updated my H9 with the pitchfuzz update. My H9 ended up stuck on some sort of “write / erase” loop, so I read in the forum to try to use the direct updater to fix this, which I did. That problem was fixed, but now about half of the algorithms on the H9 aren’t working properly and sound like garbled static. Presets like rotary just sound like scrapy feedback. Delay is the only function that still seems to be working properly. Any recommendations how to fix this?
