Home › Forums › Products › Stompboxes › H90 after amp modeler/profiler
- This topic has 2 replies, 2 voices, and was last updated 9 months, 2 weeks ago by
user404.
May 28, 2025 at 4:49 pm #190373
I would like to use my h90 after modeler (dime head namplayer) because I want stereo delay
unfortunately dimehead loop is mono, that’s why I need to put h90 after the profiler
first question: do I need to set the input of h90 as line input?
second question: what I need for to play with headphones?
dimhead has headphone output, but if I put h90 after I cannot use it
thanks
May 28, 2025 at 7:21 pm #190379
hi,
you have a lot of configuration options and i’m sure you’ll soon get great advice on that from the experts here (so i’ll leave that to them).
i came to say that i’ve been using quality headphones plugged into the stereo outputs of the H90 for two years and it has always worked great. i use a basic Y-adapter and my headphones are considered low impedance (24 ohms). i’m using denon ah-5200 but i expect any quality headphones will be fine. but i also suspect that headphone use is not recommended by Eventide. so there’s that.
i boost the output of the H90 to +12 dB to drive the headphones and that parameter is called “P out”. it’s just the right volume for me and it is crystal clear.
good luck!
May 29, 2025 at 2:53 am #190382
hi, you have a lot of configuration options and i’m sure you’ll soon get great advice on that from the experts here (so i’ll leave that to them). i came to say that i’ve been using quality headphones plugged into the stereo outputs of the H90 for two years and it has always worked great. i use a basic Y-adapter and my headphones are considered low impedance (24 ohms). i’m using denon ah-5200 but i expect any quality headphones will be fine. but i also suspect that headphone use is not recommended by Eventide. so there’s that. i boost the output of the H90 to +12 dB to drive the headphones and that parameter is called “P out”. it’s just the right volume for me and it is crystal clear. good luck!
i will try, thank you
