H90 as ABY box ?
Home › Forums › Products › Stompboxes › H90 as ABY box ?
    • #189473
      karltam
        Hi, I’m just doing research about if I can make a preset to use H90 as a ABY box or should I put a ABY box with 2 inputs after H90 to get the H 90 stereo fx and ABY function simultaneously?
      • #189477
        joecozzi
          Can you provide a little more clarity on where you want to send signal? Using the H90 insert it’s possible to split signal out of two outputs but it would be helpful to know what you’re aiming to do. A diagram would help.
