Home › Forums › Products › Stompboxes › H90 as Acoustic Guitar Preamp
- This topic has 4 replies, 3 voices, and was last updated 3 months ago by
The_Gangler.
June 9, 2025 at 1:27 pm #190542
Is anyone here using the H90 as an acoustic preamp? I would love to have the tone shaping abilities of a Grace Bix-type pedal and add some subtle compression – and have a reverb on the other side.
I’ve messed around with it a little bit, but some of the controls on in the EQ program are so technical, I’m having a hard time knowing the best way to use it in this way.
Anybody have thoughts/ideas/recommendations? Perhaps starting places for the parameters. There is a preset called “Acoustic Electric” (or is it “Electric Acoustic”), but that seems tuned to be more of an acoustic simulator?
June 10, 2025 at 3:43 pm #190589
I have not used the Grace Bix but it looks like the EQ section is made up of a low/high shelf. https://www.gracedesign.com/support/manuals/BiX_Owners_Manual_RevC.pdf
Using EQ/Compressor, you can get a similar EQ control by only adjusting the Bass and Treble controls (these are low/high shelf controls.) The frequencies of the low/high shelf in EQ/compressor are not the same frequencies that are offered in the Bix EQ circuit, so it will not be exactly the same, but it would be a good starting point. You could use the Bass and Treble controls as a starting point and the add in the other 2 bands if necessary.
https://cdn.eventideaudio.com/manuals/h90/1.9.7/content/algorithms/eq.html#eq-compressor
June 12, 2025 at 10:42 am #190605
Expanding on @tskoglund’s reply: The Flat EQ Preset is a a neutral starting point to get a feel for the algorithm. Subtle compression would be nudging the Compression parameter right of center (‘standard’ Post-EQ routing). The auto-adjusting parameters do most of the heavy lifting from there.
The two parametric bands overlap in the midrange, but it may be useful to approach Gain-Frequency-Width 1 for bass, low-mids and into the mids, with Gain-Frequency-Width 2 for midrange through upper-mids & highs. Acoustic guitar EQ is very specific to the strengths & weakness of the instrument itself, and it’s position in the mix, so no hard & fast rules here.
For example, a Bass shelving cut at 400 Hz. could be too high for a solo instrument, yet blend perfectly with other instruments. The fundamental frequencies live around 80 – 400 Hz. (open strings), The upper end of that range can bring up the warmth (slight boost) or the mud (slight cuts). So that’s within the range of Parametric 1. You can use Parametric 2 & Treble for more or less emphasis on presence and pick attacks.
All generalities, that omit your particular guitar’s characteristics. You may need to switch compression to Pre-EQ to adjust for those, for the reverb that follows, or for your playing technique. A few important point about EQ: cutting frequencies is often better than blindly boosting them. Wider “Q” is going to sound smoother & more natural on an acoustic. And don’t neglect the overtones area, say 500-2000 Hz.
June 12, 2025 at 10:59 am #190606
… some of the controls on in the EQ program are so technical, I’m having a hard time knowing the best way to use it in this way.
Here’s a technique I learned to use with parametric EQs, to zone in on where cuts or boosts need to be:
- Pick one of the parametric EQs. Dial Gain up +12 dB, Width to 1.
- You now have a very narrow, over-exaggerated emphasis.
- Slowly sweep the Frequency control over the acoustic guitar playing.
- Could be over a looped phrase, or change the Frequency with a HotKnob or EXP pedal.
This is going to help you to target exactly where your adjustments should be made.
- Once you have specific Frequencies in mind, increase the Width, and bring the Gain back down.
- Now you’ll have an idea of what & where you need to boost or cut.
- Repeat that process using the next parametric EQ.
June 12, 2025 at 12:39 pm #190609
Thank you to both of you for some great feedback! I’ll mess around with the suggestions, and see if I can achieve what I’m looking for and report back. This could be a great solution for people, like myself, that use their pedalboard for both electric and acoustic, but want to be faithful to the best of both both instruments.
Cheers!
