Home › Forums › Products › Stompboxes › H90 Bluetooth does not work on Mac Monterey
- This topic has 5 replies, 2 voices, and was last updated 9 months ago by
sumpe13.
June 23, 2025 at 4:06 am #190689
hi, I was able to, until the lates update 1.10.7 and Editor 1.9.5 to use bluetooth with Mac Monterey 12.7.6. Now, the connect to bluetooth takes the password of the H90 and keeps looping to try to connect, then resets the bluetooth of the H90 to off. I have made sure the H90 has been “deleted” from bluetooth devices on the Mac. I read someone on the forum who fixed this by upgrading to “Ventura”, which for me is unfortunately not an option. I was able to use the bluetooth function before so really hoping there is a fix to this – any help appreciated. Thanks
June 23, 2025 at 9:54 am #190693
You’ll need to “forget” the H90 from the Mac bluetooth settings, and also go into the Bluetooth settings on the H90 and select “forget”. After that, try the pairing instructions again from the start.
If you had it working before and you have not changed any settings or updated your computer’s OS version, you should be able to connect again without updating your OS.
June 23, 2025 at 5:43 pm #190708
hi tbskoglund – I already had done the “forget” step – regardless (i just remove, reinstalled, ran Utilities “First Aid” and rebooted the Laptop, fresh re-installed the Editor, and the same thing happens: it takes the password, but does not connect, lingers, and in my H90 the bluetooth then goes off, if i turn it again and repeat, the same thing happens – no bluetooth connection!
June 23, 2025 at 5:49 pm #190709
here is my “chipset” information: Chipset: BCM_4364B0
June 23, 2025 at 6:00 pm #190710
Thanks for providing that info. Unfortunately, that chipset is known to have bluetooth connection errors with Monterey. I’m not sure how you were able to get the connection to work before if you have not updated your OS version.
The only thing I can recommend is updating your OS or using a different device. Sorry for the inconvenience.
June 23, 2025 at 7:07 pm #190713
Ok. thanks. I am getting the ” Timeout waiting for response: Expected Response ID(0x71)!” – if I downgrade the H90 and Editor, is there a version of both that is known to work? Thank you
