H90 Bluetooth permanent on!
Home Forums Products Stompboxes H90 Bluetooth permanent on!
Viewing 4 reply threads
    • #194258
      uwehaas
        I am using my H90 in a studio setup connected permanently to H90 Control.
        It would be great, if the Bluetooth setting in the H90 could stay on or remembers the last state, as I have to turn Bluetooth on everytime…
        Or am I missing something?
        Thank you
      • #194260
        Securb
          No, you are not missing anything every session. I have to remember to turn on the H90 Bluetooth. The H9 comes on automatically.
        • #194277
            The H90 should remember the Bluetooth settings after a reboot.
            If you turn Bluetooth on, and then power cycle the pedal, does Bluetooth always turn off? If that is the case can you please email support@eventideaudio.com with a video that shows this? It would also be helpful to send in your pedal logs, see #1 here: https://cdn.eventideaudio.com/manuals/h90/1.9.7/content/h90-control/edit.html#parameters-edit-menu
          • #194278
            uwehaas
              Now I found out, that the H90 remembers its Bluetooth state, if my Mac is turned on before!  the H90.
              If there is the corresponding Bluetooth signal before I turn the H90 on, the H90 seems to turn on Bluetooth as it is the last state.
              But if I turn on the H90 first – which is the normal procedure –   then the H90 does not turn Bluetooth on.
              I did send the pedal log via mail.
              Thank you for your help
            • #194326
              Securb
                It would be challenging for me to send you a video. If I simply power cycle the pedal, the Bluetooth comes back on. It is when I rehearse with my band, shut down, and return a week later that the Bluetooth is once again off.
