H90 connection to Roland JC40
Home Forums Products Stompboxes H90 connection to Roland JC40
    • #189260
      kenislav
        How do I connect the H90 to a Roland JC-40, which has -10 dBu (1 M ohm), fx L/MONO, R jacks: -10 dBu (22 k ohms)? Do I need to reduce the output gain?”
      • #189268
        Borja Caro
          no need!
          if you want to play by the book just set the H90 to instrument output instead of line if you are inputing on the front.
          if you’re inputing the H90 on the back (on the fx loop) set the h90 main out to line.
          I have been giving my JC-40 line impedance with no problem anyway…
          if I’m not wrong it will be harmless as its solid state…
          anyone please correct me if I do am wrong!
        • #189296
          joecozzi
            This video shows you how to set operating levels for the input and outputs: https://youtu.be/5y14LwN9oAk?t=2090&si=3y9Mo-H51t1X5R5l
        • The topic ‘H90 connection to Roland JC40’ is closed to new replies.
