H90 connection to switcher- gigrig g3 atom
Home Forums Products Stompboxes H90 connection to switcher- gigrig g3 atom
  • This topic has 1 reply, 2 voices, and was last updated 1 year ago by joecozzi
    • #183290
      jtdoherty
        <p style=”text-align: left;”>Guys, I was struggling to connect the H20 up to switcher properly. I want to connect it in dual routing mode and have connected io 1/1&2 to loop 1 and 3/3&4 into loop 6 of the Atom G3. I’m getting a small volume drop just enough to take the edge off the amp when the HD is in the Signal chain. I have lip and lick with the drives in between. No matter which way I organise the presets in parallel or in series and on the either path I still get the problem. I’m wondering if you could help.</p>
      • #183291
        joecozzi
          A few questions to determine what could be causing the change in volume:
          -Are both H90 paths being routed to the front of the amp?
          -Is either path being directed to the amp’s effects loop?
          -What other effects are in the signal chain along with the H90?
          I’m not sure what you are saying here. Are you saying you have drives in between both H90 paths?
