Home › Forums › Products › Stompboxes › H90 Control – Create user preset
- This topic has 7 replies, 4 voices, and was last updated 6 months, 3 weeks ago by
brock.
August 28, 2025 at 4:56 pm #191783
Hi, I have a simple question:
I don’t find how to create a user preset with the H90 Control software.
I can do it on the H90 itself, as described here https://cdn.eventideaudio.com/manuals/h90/1.11.4/content/edit-modes/presets.html#saving-presets
But how can I do it with H90 Control?
August 29, 2025 at 3:16 am #191815
Select a blank program from a user bank (top left), you’ll see 2 blank presets. Click on A (above the parameter box), click on ‘presets’ (bottom right), select an effect type (eg delay) then the algorithm (eg Digital Delay), then choose a preset from the list on the left.
OK so far?
Select B (where it says B above) and do the same for that one.
Adjust all the parameters to your liking.
Rename the prog and press ‘save’ (top right)
Simples.
August 29, 2025 at 5:09 am #191816
Thanks you, but this is not what I want to do.
You explain how to save a program of two presets in the user program list, which I know how to do.
What I want is to save just one preset (just one algo) in the user preset list, not a program (made of two presets) in the user program list.
It seems it is not feasible with the H90 control. However this is feasible on the H90 itself (see https://cdn.eventideaudio.com/manuals/h90/1.11.4/content/edit-modes/presets.html#saving-presets)
I hope I’m missing something because this would be very useful.
August 29, 2025 at 5:14 am #191817
The user Program list is for storing Programs, not Presets. Presets are stored in the Library, as mentioned in your manual link. I don’t have my H90 plugged into my PC at the moment so can’t check, but am pretty sure there’s a way to save the Presets at the top of each individual Preset (A & B) section in H90 Control, and you can also access the Library too. Probably worth reading this section of the manual:
https://cdn.eventideaudio.com/manuals/h90/1.11.4/content/h90-control/index.html
August 29, 2025 at 5:28 am #191818
Thank you!
I already have read all the manual regarding H90 Control before asking. I did not find how to save presets.
Like you, I was thinking there’s a way to save the Presets in H90 Control. But it seems there is no way. Except if I’m missing something obvious?
There is only one “save” button which saves the program in the program list. But I can’t see any save preset button.
August 29, 2025 at 5:55 am #191819
You’re looking for a drop down menu (●●●) with Save to Library under its selections. #12 in this image …
https://cdn.eventideaudio.com/manuals/h90/1.11.4/_images/h90control_parameters.png
… or above #3 in this image:
https://cdn.eventideaudio.com/manuals/h90/1.11.4/_images/h90control_presets.png
August 29, 2025 at 6:05 am #191821
Yes! That’s it!
Thank you so much.
Don’t know why I missed it.
Have a nice day!
August 29, 2025 at 6:34 am #191822
Great. We help each out out here. I’ve been using H90 & Control since the release. Quite frankly, I’m still finding new ways to use them, that seem so obvious once I’ve stumbled upon them.
