H90 Control 1.9.13
(Requires H90 firmware 1.9.4+ / dot9 firmware 2.2.7+)
General
- Improved Drag-and-Drop Behavior
- You can now choose between copying and swapping when you’re dragging a program within the playlist. “COPY” and “SWAP” boxes are painted over the destination row to indicate these 2 options.
- Drag and drop is now possible on iPad: press and hold a row in the playlist or the “Programs” tab to initiate a drag and drop.
- Dragging and dropping to the current playlist no longer automatically loads the program, unless you drag to the current program row.
- Some aesthetic changes, such as dimming the row when you press and hold it to indicate that you’ve initiated a drag and drop operation.
- New Warning Prompts
- You’ll be warned when dragging to/from the current program if it has unsaved changes.
- You’ll also be warned before copying over a program if it’s the only remaining copy of that program in the library.
- Auto hide the home bar on iPad.
Bug Fixes
- Fixed an issue where favoriting a program in the library view wouldn’t show the heart for other instances of that program.
- Fixed playlist popup menu bug: copy, paste, and other actions now target the clicked program instead of the currently loaded one.
