H90 Control Latest – H90 Control 1.9.5
Home Forums Products Stompboxes H90 Control Latest – H90 Control 1.9.5
Viewing 0 reply threads
    • #189841
        H90 Control 1.9.5 (Requires H90 firmware 1.9.4+ / dot9 firmware 2.2.7+)
        General
        • Add algorithm and preset selection popup menus to the program header on the Edit tab. Press the algorithm name to reveal the algorithm popup menu. Press the preset name to reveal the preset popup menu.
        • Render parameter groups as outlined rectangles instead of separating them into different tabs.
        • Add global UI scaling. Zoom In, Zoom Out, and Reset Zoom functions are available in the top-left burger popup menu on the Home screen.
        • Support device registration through H90 Control. If a connected device is unregistered, or if it’s registered to a different user, H90 Control will prompt you to register it to your Eventide account.
        • Display the program number next to the program name in the header.
        Bug Fixes
        • Fix an issue that prevented Performance Parameter mapping from H90 Control.
        • Fix first program load after changing program lists not working.
        • Fix Bouquet Delay’s “Stereo Tap” parameter (some values in the range were being skipped when turning the knob).
    • The topic ‘H90 Control Latest – H90 Control 1.9.5’ is closed to new replies.
