Home › Forums › Products › Stompboxes › H90 Control lists question + hacking spillover
- This topic has 5 replies, 2 voices, and was last updated 2 years, 7 months ago by
joecozzi
Eventide Staff.
May 9, 2023 at 11:20 am #171110
Greetings. I’m a longtime 2-H9s user switching over to the H90, or trying to. For background, I play 2 different instruments with different output levels in 3 different bands. For gigs I’d like to be able to easily reorder programs so I can just hit “next program and load” on my external foot switch and be ready to go.
1. There isn’t a lot of documentation for H90 control. Here are things I’d like to do. I’m not sure if these are “how do you?” or feature requests.
a. Drag and drop to reorder in a playlist. Right now if you drag a program onto another one, it overwrites the other program. If this isn’t currently possible, perhaps there could be shift-drag or ctrl drag for “insert between” or “switch slots with.” I almost never want to overwrite a program with another when editing a list.
b. Create a part of custom “INIT” presest that I can begin from each time depending on what instrument I use (different output levels).
c. OR at least change default settings–I pretty much always hot knobs on 0 to start, not 100, and I always want spillover on time-based effects.
d. Have a master list of user programs, the way you can quickly get a list of user presets. Right now all I can see is manually copy-pasting into a self-made master list.
2. I’m trying to find a way to keep a frozen sound sustaining across 3 programs. Let’s say I set up a drone on a delay algorithm set to “freeze” in slot A in Program 1 I know if I switch programs once, it’ll keep going in Program 2. Let’s say the Program 2 has exactly the same delay preset in slot A. If I go to a 3rd program, with the same exact preset in slot A with the same settings, will it still cut off the drone, or is there a way to keep it going?
Thanks.
May 9, 2023 at 2:08 pm #171121
It’s a great suggestion. Presently, there isn’t the ability to swap presets in this manner. We can only copy a Program, paste it somewhere else as a placeholder, overwrite the new position, and re-paste the placeholder. The better way on H90 Control is clicking Programs up top and choosing the same User List as your Playlist. Then, you can drag and drop into place at will.
If you right click (or Control click) a Program, you have the option to “Delete/Initialize” to start from scratch, where no algorithms are populated in the Program. Another option, you can change the Playlist to User 2 thru User 4 to have a complete list of INIT Programs.
Spillover is on by default and set to 10 seconds. Very few factory Programs start with any hotknob or expression positions not at zero. Nonetheless, these settings are easily customizable in the Parameters edit menu.
Whenever you create a new user program, you can save it directly to your Playlist as well as any other User list on the Pedal. As already explained, on H90 Control, there is a tab called Programs up top, in the middle. On that window, there’s a “List” tab next to “favorites” that allows you to just see all factory and User lists; it’s best to select the User List you created for your Programs. Then what you can do is have the Playlist on the left window and this user list on the Program window. You are able to drag and drop Programs from the user list to the Playlist.
Say, for example, you want to start from scratch. Select User 2 as your Playlist, which is filled with “INIT” Programs. Then, click Programs and select User 1 (or your custom list) from the drop down menu next to “favorites.” Now, you can drag an drop Programs to any order on the initialized playlist very easily. Just keep in mind the Programs are organized alphanumerically.
No, this is not possible. You would have to reset the freeze after every program change. The spillover feature will continue the drone for as long as you’ve set the spillover time but eventually it will ring out. Also, if you change Programs in too quick succession while the spillover is trailing out, it will cut the spillover of Program 1 if you’re already jumping from Program 2 to 3 and 1 has not stopped trailing out.
What is possible is instead of changing Programs you manually change Presets in slot B while A is frozen.
May 10, 2023 at 5:35 pm #171164
Thanks for the reply. I’m on the road but will investigate when I get home. Interesting on the slot B idea.
What I can tell you now is that all of my H9 presets imported with the hot knob at 100 and spillover off. The H9 had spillover on and the hot knob either at 0 or 50 depending on the preset, so perhaps it’s a bug or translation problem.
May 10, 2023 at 5:52 pm #171165
It’s great that you’re reporting back, it’s great feedback. Hmmm, the H9 never had spillover so that’s why we’ve decided to leave it off on an H9 list or preset import. With regards to the hotknob settings, you’re saying that you personally programmed hotknob/expression settings at 0 or 50 but they’re all importing maxed out, correct?
May 10, 2023 at 9:47 pm #171166
The H9 has a setting where if you bypass it, the effect continues to ring out. Not the same as spillover on the H90 but serves a similar function. In any event, I think the default for imported H9 presets should be on, like for the INIT presets.
And yes, you are correctly reading my comment on the hot knob/expression settings.
Both things seem like easy fixes in updates. Of course, since I’ve done my H9 import now, this won’t affect me. I just put on some music and a bunch of mouse clicks later is was fixed but I thought it important to report.
I would LOVE to see improved list editing features though. It would be nice to easily reorder programs for gigs where you have different setlists without making a whole new list.
Oh, and it would be great if there were a way to use a foot pedal, aux switch, or MIDI command to change a preset in a slot B as you suggested. Right now it looks like that has to be done by hand, which is great for bending over the pedalboard for the end of set feedback wash but maybe not for switching to the middle eight.
Thanks again!
May 11, 2023 at 9:59 am #171176
I can’t reproduce this issue. When I create a preset list and map a range of expression from zero to max but save the preset with the parameter at 50%, it still imports properly, with my expression ranges intact and the value I saved the preset on.
Maybe we’re not talking about the same things.
