Home › Forums › Products › Stompboxes › H90 Expression Pedal Calibration
- This topic has 3 replies, 2 voices, and was last updated 3 years, 8 months ago by
joecozzi
Eventide Staff.
November 15, 2022 at 1:10 am #166708
Help! I can’t calibrate a Mission Aero EP-25 PRO expression pedal to recognize max travel. I went to System > I/O > Exp & Aux > Calibration but that didn’t seem to work.
So far the system recognizes the heel down (as zero) which is correct but as the pedal travels from heel forward, the mapped parameter goes to max mid through expression pedal travel range, and then as the expression continues from mid to to max, the parameter just comes back down to around 45. Weird…
I believe that what I’m missing is how to set the heel all the way up to map to 100% of the parameter. How is this done?
Big Thanks!
November 15, 2022 at 1:27 am #166709
Hi DaGuy,
First off, always make sure you’re connecting your cable to the pedal first, then plug it into the H90 so it senses the proper load.
Did you set Calibration to ON? Did you rock the pedal back and forth so the H90 could sense the full range of your pedal? You know it’s working when it’s registering zero at heel and 100 at toe.
The Mission EP-25 PRO Aero has polarity switches on each output. Perhaps you need to change it to work properly with the H90.
November 15, 2022 at 7:33 pm #166741
Got it to work. My bad. I was using an unbalanced cable… Got a bit too excited to check things out. Thanks for jumping into the abyss with me.
Cheers!
November 15, 2022 at 9:24 pm #166748
Thanks for reporting back. Glad you figured it out!
