Home › Forums › Products › Stompboxes › H90 Feature Request (Midi)
- This topic has 7 replies, 3 voices, and was last updated 1 month ago by
PhilippeG.
January 20, 2026 at 7:22 am #194324
Please can you add a value option after CC for the transmit options.
Currently its “exp1/2/sw1/2/3/4/5/6” for the first Knob, “CC#” off-127 for the second knob and the 3rd is blank, so there is easily space to add a 3rd parameter on the last knob.
Adding the ability to assign a value to the CC messages makes the H90 a viable replacement midi controller for many small to medium boards. (in my case it removes the need for a dedicated midi device to manage my Quad Cortex looper)
January 21, 2026 at 11:37 am #194336
The ability to add a channel number (corresponding to the receiving device) would be an important and… so necessary development!
Thanks
January 21, 2026 at 4:30 pm #194338
YES! but id settle for just controlling the message.
January 22, 2026 at 10:25 am #194350
What CC value would you like to transmit? The current function allows you to send low/high values (0 and 127) which should work for toggling parameters on external devices. Can you be more specific?
January 25, 2026 at 2:16 pm #194367
i have also just noticed there isnt a way to turn OFF the PC transmit when changing presets. it would be good to be able to de-couple them (otherwise anything downstream that accepts PC messages is forced to change)
January 27, 2026 at 5:16 pm #194364
hi, certainly. When a midi CC message is sent, it is sent on a channel (1-16) , and is sent with both a CC# and a value assigned.
presently the CC is sent with a global value of (i think) 0
2 exmples from the quad cortex:
FOOTSWITCH CONTROL
CC#35-42, sent with any value control a “press” of Footswitch A – H – This worksSCENE RECALL
CC#43: Scenes.
• Value 0: Scene A.
• Value 1: Scene B.
• Value 2: Scene C.
• Value 3: Scene D.
• Value 4: Scene E.
• Value 5: Scene F.
• Value 6: Scene G.
• Value 7: Scene H.In this second example, the H90 midi message is only able to activate Scene A, not B-H, because it only ever sends message 0.
Hope This Helps
QC Midi REF – https://neuraldsp.com/manual/quad-cortex?srsltid=AfmBOopfV8YNzyaDilsRUkVFduNTFLXHIvTbVKB4C8YFe697HD3v5NHZ#Incoming-MIDI-CC-List -
February 16, 2026 at 7:25 am #194584
Hello, What CC value would you like to transmit? The current function allows you to send low/high values (0 and 127) which should work for toggling parameters on external devices. Can you be more specific?
Is there any update on whether this is something that can be put on a roadmap?
February 16, 2026 at 5:10 pm #194617
hi, certainly. When a midi CC message is sent, it is sent on a channel (1-16) , and is sent with both a CC# and a value assigned. presently the CC is sent with a global value of (i think) 0
You’re right! That are basics !
– PC command with a value
– CC command with both the number “identity” for the command and a value
Without that, it can’t be usable.
Please, Eventide, how to proceed?
Thanks
