H90 : I/O impedance
Home Forums Products Stompboxes H90 : I/O impedance
Viewing 0 reply threads
    • #193758
      PhilippeG
        In its technical data sheet, I can read :
        Input : Inst : > 600 kΩ – Line : 80 kΩ – recommended : > 10 kΩ – Gain max : Inst +4 / Line +14 dBu
        Output : 220 Ω Inst or Line
        1) Whats the output gain ? different for Instr or Line ?
        2) OK for such a low output impedance for the Line setting, but it’s very very low for plugin to an amp input (Instr level should be generally over 10 kΩ)
        3) Line Input level indicated at 80 kΩ : really ???    Generally, devices’s output Line level are < 1000 Ω : very far from 80 000 Ω !
        Moreover, is there a setting for a general Input Gain ? and for an Output Gain ? (independent of the Presets & Programs)
        Thanks
