H90 inputs: merging 3/4 with 1/2 – edit
Home Forums Products Stompboxes H90 inputs: merging 3/4 with 1/2 – edit
    • #194224
      unguitar
        Sorry, found the original post here:
        H90: connecting multiple inputs (one stere plus one mono)
        I think I asked this before but can’t find the answer plus I hope that newer updates have made possible to have inputs 3/4 feed the fx chain as duplicates of 1/2.
        They would act as a sort of input mixer.
        Coming from Eventide old hardware boxes (still own my h8000FW) I have the expectation to find such simple option on a modern box.
        Thank youuu
      • #194228
          I’m not sure if this fits your criteria, but it may end up being helpful:
          Using the H90 as a Mixer (timestamped)
          • #194229
            unguitar
              Thank you,
              yes, this is the technique I’ve been using so far.
              I was hoping for a solution at system level so that you don’t have to set and save this insert per preset.
            • #194230
                Sorry, there are no updates that allow you to do this at a system level. You’ll need to save each Program with the insert enabled.
