H90 INSERT QUESTION
Home Forums Products Stompboxes H90 INSERT QUESTION
    • #166762
      lelevox
        It is possible that the signal will only be processed through one of the inserts when the unit is bypassed?
        Or do I need to create a preset where the 2 algorithms are off and insert 1 on?
        For example with a delay connected to insert 1 I want the signal to be processed only by the external delay without the sound of the two algorithms.
        Thanks
      • #166766
        joecozzi
          Correct. Or, what I would do is map a Hotswitch in PERFORM mode on that Program to bypass both Preset A and B with one switch.
