H90 Insert Request
Home Forums Products Stompboxes H90 Insert Request
Viewing 0 reply threads
    • #167378
      joshofsorts
        Any chance in the future of a global setting on the H90 where the inserts are always active, even when a program is not? E.g. when a program is active, the routing is per program; when no program is active, inserts are still active and routing goes insert 1 -> insert 2 by default? Or is this not something physically possible with the hardware?
        I think this would make the inserts more useful for people using the H90 within a larger pedalboard. Gain/fuzz pedals could go in one insert, and modulation/time-based effects could go in the second insert, thereby allowing the H90 to fall at any point in the chain with the other effect, but also for the other effects to work as normal when the H90 does not have a program active.
        Thanks for the consideration!
