Hi
I’m having trouble getting the H90 Looper in FX slot B to respond to the correct MIDI CC control assignments from the Morningstar MC6 Pro
The CC messages set to Switch B for Play, Record, Stop, Redo, and Erase work fine for the first press only. However, after the first press, H90 appears to become confused and responds only with the last received CC, regardless of the CC number sent.
Running the latest H90 Control and firmware
Control Assignment settings in H90 Control
Switch B
Play = CC#81
Record = CC#80
Stop = CC#79
Undo/Redo = CC#86
Erase = CC#85
Morningstar MC6 pro
All CC values set to send the value of 127
Does the H90 also expect to see a CC value of 0 for some of these functions?
