H90 Looper – simultaneous record
Home Forums Products Stompboxes H90 Looper – simultaneous record
    • #193327
      Wardy66
        Hi
        Is it possible to trigger two loopers to record at the same time via MIDI?
        Once recorded (in parallel routing)  I could adjust the lengths to go out of sync with each other, or mess around with speeds, but based on the same loop input.
        Might be easier for me than trying to record two inputs the same but separately!
        Thank you
      • #193329
          Hi Is it possible to trigger two loopers to record at the same time via MIDI? Once recorded (in parallel routing) I could adjust the lengths to go out of sync with each other, or mess around with speeds, but based on the same loop input. Might be easier for me than trying to record two inputs the same but separately! Thank you .
          Here’s my approach: … Two Looper Algos At Once.  You can easily substitute three MIDI CCs [127=ON values] for the Aux switch mappings described there.  The key is to map the same ‘trigger’ to pair up REC, PLAY, STOP Performance controls in both instances.
          • #193330
              This is the way 👆 Thanks Brock!
          • #193334
            Wardy66
              Thank you Brock!
              I’ll experiment later with my Morningstar MC8 Pro.
