Home › Forums › Products › Stompboxes › H90 MIDI change program and set to bypass
- This topic has 6 replies, 4 voices, and was last updated 1 month, 2 weeks ago by
Bluefish.
January 28, 2026 at 4:04 pm #194425
Is there a way to send a PC to change the program and simultaneously send a CC to switch it to bypass? Got it figured out on the H9, but for some reason the H90 will not do both. I know I can save a program as bypassed, but sometimes I need the program to start active and sometimes bypass. It would be loads easier if I did not have to have two programs with the same presets for a bunch of programs. I am using a Boss ES-5 to send the MIDI commands.
January 29, 2026 at 11:52 am #194434
This is currently not supported, but it’s on our todo list for a future update.
January 29, 2026 at 2:54 pm #194437
Bummer. Thanks for letting me know. Saves me some fruitless futzing.
February 1, 2026 at 1:54 am #194469
If your midi switcher can add in a delay action before sending the CC, the H90 is ready to receive a cc approx 300-350msec after changing programs
February 2, 2026 at 10:05 pm #194482
Unfortunately, I am not finding that in the manual. I will keep digging. Thanks for the suggestion.
February 4, 2026 at 1:28 pm #194495
I select H90’s programs from MobileSheets appli.
In the midi command, I send first a PC to select the program, then a CC to turn of the footswitch P.
So, the program is avalable but not active at the beginning of the song.
February 4, 2026 at 10:01 pm #194496
That is an interesting idea. Thanks
