H90 MIDI – Two Questions
Home Forums Products Stompboxes H90 MIDI – Two Questions
    • #183421
      ThatCrazyBeat
        Hi All. Two questions:
        1. Bank Mode: I see that I can enter “Bank” mode via MIDI – Global Ctl. This is working fine. How do I exit Bank mode via MIDI?
        2. Perform Mode: How do I access 2nd page of Perform mode via MIDI?
        Thanks.
      • #183423
        joecozzi
          You can exit Bank mode by using the mode toggle command found in the global MIDI mapping menu. It’s not possible to access the second page of Perform mode via MIDI, but you can use the Perform 1,2,3…6 options to access Performance functions on your MIDI controller directly.
        • #183426
          ThatCrazyBeat
            Thanks, Joe. I found that I could get back and forth between standard “select” view and “bank” view (both being within “select” mode) by toggling between the combination of entering Bank mode and entering Select mode.
            I definitely have some more work to do to find “my” workflow. Much appreciated.
