Home › Forums › Products › Stompboxes › H90 Mono vs Stereo Input
- This topic has 5 replies, 2 voices, and was last updated 9 months, 1 week ago by
Eventide Staff.
May 19, 2025 at 11:06 am #190213
Hello everyone,
I’d like to try my H90 pedal as an aux effect with my mixing console (in “kill dry” mode).
Can I expect any audible difference if the FX send feeding the H90 is layed out in stereo or if it’s mono (which would save me a mixing bus)?E.g. if an instrument is panned hard left and sent to the pedal’s IN 1&2 (stereo), would the resulting reverb, or any other effect, also be “panned” somehow?
Thank you.
May 19, 2025 at 11:38 am #190214
The H90 will automatically process your signal in mono or stereo, or mono in > stereo out / stereo in > mono out. This is all configured depending on which physical inputs/outputs are connected to the H90.
The most noticeable difference will be whether you are using the stereo output of the H90 or not (the effects will produce a nice stereo image when you are using stereo outputs). Some effects (certain delays, Harmonizers, etc) have individual delay lines for the L/R channels. So if you are using the pedal with a stereo input/output, and you only send a signal to the left input, you will only be using the left channels effects processing.
I would suggest giving your setup a shot and trying a few programs/presets that use various algorithms and see how you like it.
Let me know if that answers your question.
May 20, 2025 at 9:54 am #190225
thanks, but what you explained was already clear.
My question is:
Do the effects produce a different wet signal with “mono in => stereo out” than with “stereo in => stereo out”?
Or in other words: does then pan position of the incoming signal make any difference to the pure effect signal? -
May 20, 2025 at 10:28 am #190228
In certain situations, yes the panning of the input source will make a difference for how the effects processing works. I mentioned this in my original response:
“Some effects (certain delays, Harmonizers, etc) have individual delay lines for the L/R channels. So if you are using the pedal with a stereo input/output, and you only send a signal to the left input, you will only be using the left channels effects processing.”
May 25, 2025 at 3:51 pm #190337
I see.
So it seems for the majority of algorithms, using a stereo input would have no major impact (which is good in my case).
Thank you! -
May 27, 2025 at 8:54 am #190344
You’re welcome.
Yes, I don’t anticipate that you will run into any issues. Just try a few variations of Presets/Programs with different effects with the setup to confirm it works for you.
