H90 Output question: TRS-XLR? DI?
Home Forums Products Stompboxes H90 Output question: TRS-XLR? DI?
Viewing 3 reply threads
    • #190302
      tzudan
        Hi everyone, I’m using a H90 for my vocal in live situation.
        My signal chain includes a preamp before H90, so I set the input and output of H90 both in Line Level.
        I’m thinking of using TRS-XLR Male cable for the output and direct to PA( or maybe through stage box).
        However, the manual said that H90’s output is ¼” MONO TS jack.
        Is using a TRS-XLR Male cable for the output a good idea? Or should I use a DI instead?
      • #190303
        tzudan
          Or just a Line Isolator?
        • #190320
            The H90 does use unbalanced TS connectors for the input/output jacks. You should be fine if using a TRS > XLR cable for the output connected directly to a PA. You could also get a TS to XLR cable but that probably would not make a difference compared to the TRS > XLR cable.
            A DI would be a good option if you run into any issues with the TRS > XLR cable.
          • #190510
            Bob Foster
              I bring DIs in case there is a hum issue. Pro venues will probably also have some on hand.
