Home › Forums › Products › Stompboxes › H90 program: Looper + Reverb Spillover Problem
- This topic has 3 replies, 2 voices, and was last updated 1 year, 1 month ago by
Eventide Staff.
February 15, 2025 at 10:50 pm #188185
Hello all, I have a program on my H90 that is the basic looper that runs into a big hall reverb so I can make pads to play over. I was messing with it a little bit earlier today trying to get some of the CC functions to work and eventually gave up on that, but after I did that now the spillover function is not working when I get out of that program. I have checked everything I can think of and even taking a screenshot of my parameters and rebuilt the algorithm from scratch but that didn’t help either. I use a Morningstar MC6 pro to change programs. But it’s a fairly simple PC message. Any suggestions on what good fix the spillover problem?
February 17, 2025 at 10:00 am #188195
Sorry to hear you are having issues. The only setting that will determine how spillover works is the spillover time in the system settings. Have you confirmed the spillover time is higher than 0? Something like 10-15 seconds is a reasonable time to use.
How are you using the pedal when you say that spillover is not working? An easy way to confirm that it is working is to create a long reverb or delay tail, play a chord or note, and then switch programs. The tails should keep going after the new program has loaded.
February 17, 2025 at 10:35 am #188196
Hello and thank you for your response. I’m now thinking it’s something to do with the way I have my Morningstar MC6 pro configured. I used that particular program yesterday morning at church and it worked fine but I did have some issues I need to correct with the MC6 pro. I don’t know what was going on with it when there was no spillover but it seems to be working fine now! If it has problems again I may reach out!
February 17, 2025 at 10:52 am #188197
Great, glad to hear it is working for you again. Feel free to reach out if you need further assistance.
