H90 Sequential routing, parallel input
Home Forums Products Stompboxes H90 Sequential routing, parallel input
Viewing 3 reply threads
    • #193181
      TOTAL
        My groove box has two pairs of outs so I wonder whether it is possible to set the H 90 in such a way that four cables get in, whereas the internal routing is sequential, meaning that only a pair of stereo go back to the groove box.
        This would give control of wet per either effect to every groovebox channel
        Fabulous device, by the way.
      • #193244
          Can you list exactly which groove box model you’re using?  That will help to tailor the routing to the specific capabilities of that groove box.
        • #193254
          TOTAL
            Sure. MC707 by Roland
            Stereo Send, RETURN
            Stereo Assignable Out, External In
          • #193255
            TOTAL
              <p style=”text-align: left;”>It is possible to make them assigned to onboard reverb and delay channels having each zero to 100% wet although in either case it is on top of the 100% dry.</p>
