Home › Forums › Products › Stompboxes › H90 Toggle between saved and current settings
Is there a way to toggle between the last saved and the current settings to know if it is worth saving – overwriting the preset?
No there is currently no way to do that. If you overwrite the Program/Preset there should still be a copy of it in the library. You can use H90 Control to quickly brows the library and load the previous Program/Preset.
Okay, thank you.
