H90 triple aux switch
Home › Forums › Products › Stompboxes › H90 triple aux switch
    • #166862
      drxcm
        Anyone know what is compatible? I was looking at the Strymon multiswitch but suspect it might not work?
        are all aux switches the same?
        any recommendations?
      • #166864
        coirbidh_99
          I’m using an EHX 3-button, which works fine. I would expect most 3-button switches that are *not* the Strymon switch to work with the H90. (I’m also unclear on whether the Strymon switch works with non-Strymon products, or the other way around. I should probably plug the EHX switch into my Volante and test the idea.)
        • #166865
          apalazzolo
            I had a standard aluminum enclosure and two standard non-latching (momentary) footswitches hanging around.  Nothing special.  I just wired it up and it worked like a charm.
