H90 vocal presets and programs?
Home Forums Products Stompboxes H90 vocal presets and programs?
Viewing 4 reply threads
    • #193014
      ErlingMox
        Missing more good H90 presets and programs for vocal. Not so interested in harmonizing and autotune, but want delay, reverb, EQ comp, micropitch presets and programs for vocal. I have for instance tried to find the parameter settings for Eventide H9000 #6710 B-vox Delays+verb but it is not available anywhere. Maybe Eventide or anyone could help with more vocal presets please.
      • #193025
          There is a dedicated “Vocal” Program list. You can use H90 Control to check out these Programs easily.
          • #194299
            mojozart
              I have a question about the Vocal and Granular, etc. program lists that are provided in the Control App:
              Is there a way to copy these to the device? Or to download or export as a .lst90 file?
              I only figured out how to create a new list and copy programs individually. I didn’t find a way to install the whole list on the device.
            • #194307
                These Programs can be found on the pedal by using Programs edit mode. Press the Programs button and turn Quick Knob 1, you will see the Granular and Vocal lists, among others: https://cdn.eventideaudio.com/manuals/h90/1.12.5/content/edit-modes/programs.html
                The Granular and Vocal lists are Factory lists and cannot be selected as your Playlist to scroll through when using the pedal in Select mode. The idea is that these Programs are starting points and you can pick and choose which ones you like, and then copy them to your User list.
            • #193058
              ErlingMox
                Thanks. Looking forward to checking them out. Slowly learning more about H90. One more question; is there anywhere you “reveal” the actual parameter settings for the famous Eventide H9000 vocal programs like #6710 B-vox Delays+verb?
              • #193062
                  That exact algorithm is not on the H90, but the effect is made up of a ducked delay feeding a nice reverb. You can recreate this on the H90 by using the Ducked Delay going into the Hall reverb in series.
                  Below are the parameters from the H9000 algorithm so you can copy the delay time and reverb decay settings. You should be able to get close
                • #193072
                  ErlingMox
                    Thanks. Appreciate it !!!! I would be overjoyed if you could share a few more screenshots of parameters of the famous and “normal” like in not experimental H9000 Vox programs/ algorithms so I can try to set something similar on my H90 🙂
