H90 wet dry issue
Home Forums Products Stompboxes H90 wet dry issue
  • This topic has 2 replies, 2 voices, and was last updated 2 years ago by joecozzi
    • #178421
      zperry94
        Hi all,
        I was playing my board at church on Wednesday, and I noticed an issue. My signal was uneven between my left and right channels (right being about 10db higher), and my wet effects were pushing only through my left channel. When I went home to duplicate the problem, I have isolated the issue to the H90. Even in bypass, when the H90 is in my chain, I have this issue. When it is not, I don’t. For context, I am running my H90 in dual mode, stereo in and out, with the following wet effect path:
        Mobius -> H90 (ins and outs 1/2) -> Timeline -> H90 (ins and outs 3/4) -> Bigsky -> Iridium -> Out
        Any help would be greatly appreciated
      • #178422
        joecozzi
          Try connecting your guitar to input 1 and coming out 1&2 in stereo directly to your Iridium. Do you still notice a problem? For testing purposes, just start out with THRU utility algorithms or bypass any presets in Path 1.
          Do the same connecting the guitar to input 3 and coming out 3&4 n stereo directly to your Iridium. Anything issues? Same thing, for testing purposes, just start out with THRU utility algorithms or bypass any presets in Path 2.
          This isolates both paths of the H90 to send if it is in fact an H90-related issue.
        • #178423
          joecozzi
            Of course, I’m assuming you’re using Dual routing mode here.
