H90 Wet/dry/wet
Home › Forums › Products › Stompboxes › H90 Wet/dry/wet
    • #188296
      bru
        Should we use isolation transformers with three guitar amps in Wet dry Wet configuration?? or are the H90 outputs isolated???
      • #188310
          This will depend on many variables. Try setting it up with your amps without them first and see if you have any issues before introducing anything else to your set up.
