Home › Forums › Products › Stompboxes › Harmonized Lead with two Guitars (80’s Metal Style)
- This topic has 4 replies, 3 voices, and was last updated 8 months, 3 weeks ago by
brock.
April 25, 2025 at 6:10 pm #189760
I am trying to find a patch that will output a high gain, harmonized lead sounding like 2 guitars. Think 80’s Metal like Iron Maiden/Judas Priest/Metallica.
Has anyone made or found a patch like this to share? I have been poking around in Patchstorage to no avail.
I’d love some guidance on making my own, but I have to admit that I am ham fisted at setting up algorithms.
Many thanks!
April 27, 2025 at 10:59 am #189784
This one may give you a head start. The base Program is set up like a unison doubler, but you can (manually) adjust Pitch A & B to say, 3rds & 5ths. The A HotKnob shifts both pitches together.
https://patchstorage.com/adt-quantize-doubletrack/
For high gain ‘internally’, try swapping out Mod Delay for any one of the distortion algorithms. I’m sure I’ve built something similar before, but I didn’t find any with a quick scan of PatchStorage.
June 24, 2025 at 10:20 pm #190727
This one may give you a head start. The base Program is set up like a unison doubler, but you can (manually) adjust Pitch A & B to say, 3rds & 5ths. The A HotKnob shifts both pitches together. For high gain ‘internally’, try swapping out Mod Delay for any one of the distortion algorithms. I’m sure I’ve built something similar before, but I didn’t find any with a quick scan of PatchStorage.
Is there anything specific you want to ask or suggest in return?
June 28, 2025 at 12:24 pm #190752
Nothing much to ask, but I can suggest a few specifics to flesh out my previous answer. There are higher gain Distortion choices, but I’d go with Sculpt. If need be, boost it using In & Out Gain controls at the Preset or Program level.
Split Mode with ‘spectral panning effects’ enhances the multiple guitar illusion, along with offset Delay A & B times in Diatonic. But this will also work in mono, or for input + one guitar harmony.
Core Program:
- Change the Key, Scale, Pitch A & Pitch B to match song harmonies.
- Program, Diatonic & Sculpt Mix all fold in some pick attack from the clean input.
- Adjust the Gate Threshold for balancing sustain vs. compression noise buildup.
QOL Enhancements:
- Control the Pitch Mix with [A] HotKnob, Band Mix with HotKnob, and [P] HotKnob for control over both.
- EXP pedal mapping to tame down the Low & High Drive, while dropping the X-Over frequency.
- This being the ’80’s, EXP also controls the mandatory wah action [Filter Pre, Filter Post, Env Filter Sens] here.
June 28, 2025 at 1:14 pm #190753
… Band Mix with HotKnob …
A victim of the disappearing bracketed B trick. To clarify:
- Diatonic Pitch Mix, mapped to the HotKnob (A).
- Sculpt Band Mix, mapped to to the (B) HotKnob
- Next, map each HotKnob in turn – (A) and (B) – to the (P) HotKnob.
That will give you easy access to versatile mixing between guitar voices, distortion multi-bands, or both simultaneously. Balance point for all voices & HotKnobs is at the midpoint (50).
Although it’s intended for single note lines, this Program is very forgiving of power chords, and many double-stop note combinations.
