Harmony algo
Home Forums Products Stompboxes Harmony algo
Viewing 3 reply threads
    • #113638
      markboorman
        Hi all
        Bit of a basic question so apologies in advance.
        My band wants to do a few tracks where I need to play dual guitar lines in harmony- Queen, Lizzy, you know the kind of thing. I have the H910 and Crystals algos but think the Diatonic one might be best suited. Am I correct? If not, what would you recommend?
        Thanks
      • #144117
          The Diatonic algorithm is what you want.  Two additional harmonies, with both intervals constrained to scale & key.  Plus a full featured dual delay, with some unique feedback routing.  QuadraVox will give you four additional voices in scale & key.  Both have the same maximum delay time, with QV carving that time into rhythmic patterns [no feedback].  Either one can enhance the doubling illusion with short delays & panning FX.
          Keep in mind that for some of those classic songs, you’re going to need a way to change the harmony intervals, or even the key / scale at certain ponts in the song.  An Aux switch, expression pedal, or MIDI can make those transitions easier, but switching between complementary presets would work.
          • #144129
            markboorman
              Thanks Brock. I run an aux and an exp pedal so should be able to work it out. Any suggestion on which one to get? I can’t see 4 harmony parts being common so the diatonic looks favourite as it has the 2 separate delays.
          • #144133
              Diatonic is the working man’s pitch algorithm. Two voice ‘intelligent’ harmonizer, any key, 13 scales.  Pristine dual digital delays; 0 ms. to about 1.5 seconds.  Zero to infinite feedback, and a unique, musical routing based on the longer delay time.  PITCH MIX is in a position that allows delay trails and looping.
              Four harmonies can get a little thick in a live scenario.  Sometimes that can be a good thing [Hammond B3 from Hell; jazzy synth, or massive power chords from one or two notes; riff rock layered lines].  I don’t think that the pitch tracking suffers from adding 2 more voices.  Like any pitch shifter, the formants can get a little ‘cartoon-y’ at the extremes.
              Keep QuadraVox on your radar, though.  The Delay Grouping can be amazing under pedal control.  Scale-accurate arpeggios & ‘fingerpicking’, slapback 4 voice chords, and every delay rhythm in-between; all under foot control.  More for originals and experimentation than a bread ‘n’ butter covers set.  One practical technique is to take two harmonies, clone them, then spread those two doubled harmonies with short delay spacing and panning.  Powerful stuff.
            • #144142
              markboorman
                Thanks- will try that
