Home › Forums › Products › Stompboxes › Help! Can someone identify what Pitchfactor setting is being used? (WAND related)
October 27, 2018 at 12:44 am #115021
Cory Hanson of WAND uses the Pitchfactor in many ways. One of his settings uses some sort of delay/feedback maybe triggered using the hotswitch on the Pitchfactor.
I’ve tried setting the H910 and used expression to manipulate the delay/feedback but I don’t get the right results – it almost sounds like something the UltraTap is doing but he’s using the Pitchfactor to get the reults.
Any help with how this is done is much appreciated! Thanks!
https://www.youtube.com/watch?v=nE8-AD-6cPk
https://youtu.be/2pvFp2hAL5k?t=426
Pedalboard:
October 27, 2018 at 3:45 am #150412michaelpowers wrote:
I've tried setting the H910 and used the expression to manipulate the delay/feedback but I don't get the right results – it almost sounds like something the UltraTap is doing but he's using the Pitchfactor to get the results. Any help with how this is done is much appreciated! Thanks!
Have you used H9 Control? You didn't tell me you have a PitchFactor or H9 but it's OK. You can use H9 Control app to control your H9 or PitchFactor (for PitchFactor you would need a USB cable). In H9 Control there are much more presets. Please check out the F8 PHOTON BEAM preset of the H910/H949 algorithm in the app.
If you don't want to use the app, here I've attached a screenshot, from which you may see those parameters.
October 27, 2018 at 8:55 pm #150418bohan wrote:michaelpowers wrote:
I’ve tried setting the H910 and used the expression to manipulate the delay/feedback but I don’t get the right results – it almost sounds like something the UltraTap is doing but he’s using the Pitchfactor to get the results. Any help with how this is done is much appreciated! Thanks!
Have you used H9 Control? You didn’t tell me you have a PitchFactor or H9 but it’s OK. You can use H9 Control app to control your H9 or PitchFactor (for PitchFactor you would need a USB cable). In H9 Control there are much more presets. Please check out the F8 PHOTON BEAM preset of the H910/H949 algorithm in the app.
If you don’t want to use the app, here I’ve attached a screenshot, from which you may see those parameters.
Thank you! Yes, sorry – I have an H9 Harmonizer pedal. It seems like it is the Photon Beam preset that might be tweaked a little bit. THANK YOU!
October 27, 2018 at 3:48 am #150413
Forgot to mention. You may still need to tweak some parameters a bit, like mix, pitch mix, and delay time, but it should already sound close.
