Help mimicking guitar effect with H90
Home Forums Products Stompboxes Help mimicking guitar effect with H90
    • #190896
      alpargatagazer
        Hi there! I would like to know what effects in H90 would you use to get the sound of the guitar of Grizzly Bear – Colorado at 4:15. Any ideas? I guess there’s some kind of slapback delay there and ¿some filter too? Thanks in advance!
      • #190907
          I wonder if there isn’t some POG 2 in there as well.  You could probably cover all of the above in Polyphony & Auto EQ.  Or VocalShift, if you’re feeling adventurous, and want something to build those chords out of single note lines.
          Worst case, use both H90 slots to break up the filtering & slapbacks into two components.  The delay portion sounds somewhat like a brighter multi-tap to me, as opposed to a short delay with rapidly decaying feedback.  Again, you could probably simulate that with dual delays offset in time from each other.  Or substitute MultiTap UltraTap with a few Taps.
        • #190958
          alpargatagazer
            Thanks a lot for the response! I’ll try it out soon 🙂
