Hold down the left footswitch and turn on pitch factor
Home Forums Products Stompboxes Hold down the left footswitch and turn on pitch factor
    • #109400
      DavieB
        This puts it into some kind of wierd mode, not sure what the hell it is but I can't find anything in the documentation about it.
        Anyone heard of this know anything about it or what?
      • #124112
          Interesting.  It seems that you've stumbled upon an internal hardware testing procedure of Eventide's.  Once in that test mode, the encoder selects the particular type of test, and the left footswitch appears to display the test in progress, or the results of a test after it's been halted.
          01 TEST ALL
          02 TEST ALL  NF
          03 TEST ALL NL
          04 MEM ALL
          13 SYSTEM RAM
          18 DELAY RAM
          22 FLASH RAM
          31 MIDI PORT TEST
          51 ANLG AUDIO
          81 FRONT PANEL
          82 DISPLAY
          91 AUDIO THRU
          These tests take a long time to complete.  At least some of them allow your dry audio through (with the occasional decaying high B sine beep blocking that for a moment).  There are a lot of P= E= T= notations; each followed by a numerical value.  PASS – ERROR – TESTED?
          I've seen this kind of thing in many synthesizer applications, but I can't recall finding stomp box diagnostics like this.  It's usually triggered by a combination of commands that are unlikely to be hit inadvertently.  Nice find (although I'm not so sure that Eventide would agree).  Perhaps there are read/writes in the processes (or something similar) that shouldn't be interrupted.
