How do you edit current pedal settings with iOS app?
Home › Forums › Products › Stompboxes › How do you edit current pedal settings with iOS app?
    • #111922
      Lets say i load a preset on H9 hardware and tweak some settings on hardware also.
      But then i decide to load an iOS app to tweak further: I cannot find on the app where are current preset tweaking.
    • #126689
      gkellum
        Well, when you first connect the app to your stompbox, it should pull the active preset off of the stompbox.  So, after you connect to the stompbox, click on the Presets button in the menubar at the bottom and that will show you the active preset it received from the stompbox.  Also, if you change the preset directly on the stompbox and you have presets open, that will also load the active preset that you just loaded on the stompbox into the app.
