Home › Forums › Products › Stompboxes › How to control the output level by midi
- This topic has 6 replies, 3 voices, and was last updated 1 year, 6 months ago by
teruzou26.
February 28, 2025 at 7:07 am #188490
Hi. I’m a H90 beginner.
My routing is below.
Gt – OD(in a midi switcher) – Amp =(FXloop)=H90
I use only a single Program.
But when I play solo, I want more output volume.
Can I have a 2 switchable volume setting in a single program?
How should I do?
February 28, 2025 at 9:40 am #188491
This can be done using a HotSwitch. Check out this section of the user manual that explains how to do it and let me know if you have any questions: https://cdn.eventideaudio.com/manuals/h90/1.9.7/content/edit-modes/parameters.html#hotswitch
You can use the onboard footswitches in Perform Mode, or Program a MIDI controller to turn the HotSwitch on/off.
February 28, 2025 at 10:14 am #188494
Thank you so much!
Can I switch more than two volumes in a single program by midi controller?
February 28, 2025 at 10:27 am #188497
Yes, you may map however many parameters you like to a HotSwitch.
March 1, 2025 at 12:07 am #188561
How can I do if I want 3 or more steps of volume degrees in a single program?
March 1, 2025 at 10:56 am #188565
You could program all 3 HotSwitches, each one to a different level. But if you’re using MIDI, the same CC number can have 128 values. So, depending on the number of switches you have that transmit MIDI, it can be more.
March 2, 2025 at 6:31 pm #188600
Thank you so much!!!
