How To Format Conversion? .h9z →.pgm90
Home › Forums › Products › Stompboxes › How To Format Conversion? .h9z →.pgm90
    • #169157
      gqiang
        Many h9 file want to format conversion
        Thanks
      • #169165
          The conversion happens automatically in the H90 Control application.  You can export the presets from H9 Control, or download them to your computer.  Then import those same presets into the H90 Control application.
          • #169207
            gqiang
              H90 only can import “.pgm90”,can not import “.h9z”
          • #169212
              In the H90 Control app:
              • Select the Parameters tab at the bottom.
              • Up top, right-click on the 3 dots, just to the left of A or B Preset.
              • Select Import H9 ‘h9z’ Preset …
              The same process above applies in the Preset Library tab (along the bottom).
              Or go to the extreme bottom left icons in any tab, and locate the Import List icon (the 3rd / middle one of 5 icons).
              • Right-click on it, and select Import H9 List …
              There is also drag ‘n’ drop from a File Manager window on your computer, but I have never used that myself.  I like a little more control over what goes where.
              • #169214
                gqiang
                  I got it,thank you very much!
