How to program the Rose pedal Delay Mix to Expression pedal?
Home › Forums › Products › Stompboxes › How to program the Rose pedal Delay Mix to Expression pedal?
    • #172281
      rck
        Can the Rose’s Delay Mix parameter be accessed/controlled via MIDI Expression controller?
        Basically, I would like to access the Rose’s Delay Mix via an Expression pedal. Is there someway to do so?
        Thank you.
      • #172304
          What MIDI expression controller are you using? Can you customize which CC it uses?
          The Mix parameter is controlled by CC #22, so if you can set your controller to use that CC, that would be easiest.
          Otherwise, you can configure the MIDI expression pedal CC on the Rose to match the CC of your pedal, and then use the Rose’s Morph function with the mix mapped to the morph to control it that way.
          • #172306
            rck
              I’m using a Disaster Area DPC-5 first generation which has an Expression Wheel. I am aware DA does list some MIDI commands for Eventide devices including Expression control which they provide as CC 48. No, I can’t customize which CC it uses.
              -thank you for your help
