How to use space as a normal pedal in the chain- bypass
Home Forums Products Stompboxes How to use space as a normal pedal in the chain- bypass
    • #114380
      I just got my eventide space. It sounds amazing but i need to switch it on to hear the rest of my chain signal. I can’t find a normal bypass to use it as I have always used all my pedals in the chain. I have read the manual, All the three bypass options kill the signal. I have to to turn on the reverb to hear the rest of my signal. Anybody can please advise?
    • #147223
      jhyman
        Plese see below from the manual. Make sure Killdry is off, unless you have a parallel effects loop
        Killdry – Send/Return Loop
        If you’ve connected SPACE using an effect send/return loop (either your amp’s or a mixer’s), SPACE’s Killdry feature can be enabled. When Killdry is enabled, SPACE does not send any dry signal to the outputs; only the Effect. Note that when Killdry is enabled, Bypassing will mute the Effect rather than Bypass it when DSP Bypass is selected. Killdry’s factory default is disabled.
        It can be enabled in the [BYPASS] menu of the System Mode. Here’s how:
        1) Press and hold the Encoder and Right Footswitch simultaneously for a few seconds to enter System Mode.
        2) Turn the Encoder until [BYPASS] is displayed.
        3) Momentarily press the Encoder.
        4) Turn the Encoder until [KILLDRY] is displayed.
        5) Momentarily press the Encoder.
        6) Turn the Encoder to select either [YES] or [NO].
        7) Press and hold the Encoder and Right Footswitch simultaneously for a few seconds to exit System Mode.
