Insert Mode: Route Preset A to L/1 and Preset B to R/2?
Home Forums Products Stompboxes Insert Mode: Route Preset A to L/1 and Preset B to R/2?
    • #191160
      Hermetech
        Quick H90 routing question, I’m probably overlooking something very simple: In Insert Mode, is there a way to configure things so that in a Program, Preset A comes out of only the Left/1 output, and Preset B comes out of only the Right/2 output? Obviously they would each have to be mono, and I assume routed in Parallel, but that’s not a concern. Is this doable?
        Also posted on the FB group, but I usually get better/faster answers here!
      • #191166
          Sorry this is not possible, there are no discrete panning controls for presets A/B.
          However, it is possible with some newer H90 algorithms that do have panning controls. For example, Polyphony and Head Space in parallel could achieve this option.
          Alternatively, if you use Dual mode with mono connections for each path, you could use an external mixer to hard pan the A/B presets.
          • #191170
            Hermetech
              Thanks, please consider adding panning controls jn future, if possible.
