Is there a way to see two H9s simultaneously on iPad using H9 app?
Home Forums Products Stompboxes Is there a way to see two H9s simultaneously on iPad using H9 app?
    • #194464
      Skerikmusic
        Is there a way to see two H9s on iPad using H9 app? I can get both my H9s into H9 app at the same time which is great. BUT, I can only see one H9 at a time on screen, and if that particular H9 pedal is not chosen on screen when you change patches on it, the screen will not acknowledge the preset change when you change over to that view. So you’re flying blind, or you have to change the preset to another patch, then go back, which is not a useable outcome. I’m using a new iPad Air 13″ M3 version 26.2 Thanks!!
      • #194478
          No, the app can only be focused on 1 connected device at a time.
