Kill dry not working on Blackhole Immersive
Home Forums Products Plug-Ins Kill dry not working on Blackhole Immersive
    • #190972
      analogholic
        Just got Blackhole Immersive and kill dry does not work.
        It does not kill the dry sound, but kills the effect instead just like “kill wet”.
        What is wrong here?
        I´m on Mac OS Mojave and Cubase Pro 10
        Thanks in advance!
      • #190979
          This is the expected behavior, although it is different than kill dry on our stompboxes which fully removes the dry signal and only gives a wet output with a level control.
          Kill Dry on Blackhole immersive will completely mute the audio input, allowing you to hear how the tails ring out and fine tune the size/feedback/gravity etc.
          Kill Wet will only mute the wet signal (the dry signal will pass through), which is more useful when you have long reverb tails and you’d like to quickly mute them.
          If you set the mix to 100% it will be effectively the same as how kill dry works on our stompboxes. You can adjust the wet level by using your DAW’s channel faders.
