Home › Forums › Products › Stompboxes › Knife Drop preset change
- This topic has 3 replies, 3 voices, and was last updated 1 day, 21 hours ago by
teruta.
February 18, 2025 at 12:00 pm #188212
I’m sure it’s staring me in the face, but how do I change to a different preset on the Knife Drop pedal itself? H90 Control showed there are 16 onboard and it’s a snap to change preset via that and via MIDI. I just can’t figure out how to do it on the pedal itself. Please tell me what I’m missing!
Thanks,
Tony
February 18, 2025 at 12:06 pm #188213
Hi Tony,
The only way to switch presets with Knife Drop is using an eternal aux switch, using MIDI, or the H90 Control app.
Normally, with our other dot9 series pedals, the right footswtich can be used to search through presets. But since Knife Drop was designed in collaboration with Third Man and Jack White, he requested the right footswitch be used to only go to his favorite preset, the first one.
February 18, 2025 at 12:08 pm #188214
Ha! Glad I was only missing what wasn’t there. Thanks for the quick reply, Joe.
Off to add a bank to my MIDI controller…
July 3, 2025 at 6:25 pm #190831
truthfully jack white turns out is an a**ho7E.Why would they make this with presets you can’t access with the pedal …is he getting a kickback for them??? In addition the really BAD part on EVENTIDE’s end is that they do NOT tell the consumer that. Which btw is illegal deceptive advertising ….how you get sued over that…. I always respected this company and their products , but no more after this……..the original video I saw showed all the presets , and the variations with each one…that attracted me to buy it …..well seems that video has been pulled, and NONE of the other ones show you the other presets let alone how to access them , except one which shoe that whatever it is with 2 buttons one for the presets , and the other to control the midi…and then a quick showing of doing something ( not explained what exactly) with an H90 …neither tells you what they are or even how to buy them if you wanted…nor does it say you can’t access the presets ANYWHERE….in in fact this is NOT A STANDALONE ITEM , but the advertising absolutely implies it is…why is that info being hidden ?????? yes why are you willfully DEFRAUDING the public about this…So here’s the result
.. I’m returning it , also this thing is useless in a live situaTION TO CHANGE ANYTHING ON THE FLY , ALSO THE ONLINE STORE I BUY FROM ,HAS ANREP. I SPOKE WITH ..HE TOLD ME YOUR COMPANY WILL BE ALERTED TO THIS ISSUE , AND THEY ARE nOT RECOMMENDING THIS PRODUCT…..it’s a fraud……..so answer that question …why did you put out false advertising tosell this as a standalone ..and just not mentioning that IS LYING …..the sin of omission…..had I known that i would never had wasted my time buying it and now wasting my time to return it.
